Balun One Nine: cutting R1
rjzastaury
I'm finally getting around to building a SULA. I have my Balun One Nine in hand, but I'm not clear on what cutting the R1 jumper/resistor entails. Can someone please tell me how exactly to do it? Pardon my ignorance...
Thanks,
Ron
Thanks,
Ron
Egil - LA2PJ
Re: Balun One Nine: cutting R1
It is done to obtain galvanic isolation between the antenna and radio.
See here: https://swling.com/blog/2019/10/the-noo ... lun-19-v2/
73's
Egil - LA2PJ
73's
Egil - LA2PJ
rjzastaury
Thank you, Egil. I guess I should clarify my question: How do I physically cut the resistor? Score across it with a knife?
Egil - LA2PJ
Just scrape it off whith a knife... Carefully!
Good luck!
73's
Egil - LA2PJ
Good luck!
73's
Egil - LA2PJ
- Andrew (grayhat)
see hererjzastaury wrote: ↑Mon Sep 04, 2023 4:24 pm Thank you, Egil. I guess I should clarify my question: How do I physically cut the resistor? Score across it with a knife?
you just use a cutting blade to cut the circuit trace, then use a multimeter to check if the two sides are disconnected; to rejoin the connection, use a soldering iron and put a drop of tin to reconnect the sides
rjzastaury
Thanks, Andrew!
- Andrew (grayhat)
notice that the V1 has the central tap, while the V2 doesn't so with the V2 there's nothing to cut
rjzastaury
It's the V2 that I have. How is it done for the V2?
rjzastaury
Do I scrape it here?
- Attachments
- 2023-09-05_13-13-34.jpg (54.78 KiB) Viewed 194100 times
