Balun One Nine: cutting R1
rjzastaury
Re: Balun One Nine: cutting R1
Post by rjzastaury »
Or here?
that one is the V2, no need to scrape anything it does not have the center tap even if the PCB shows it :)
rjzastaury
Interesting. Thanks, Andrew.
rjzastaury
The antenna works great. That null is deeeeeep!
I'd like to put it in the rotator I have on the roof. My question now is about the recommended 3-meter height: Would that be from the ground, or from the roof itself?
Thanks for the great antenna design!
rjzastaury wrote: Fri Sep 22, 2023 1:11 am The antenna works great. That null is deeeeeep!
from the "ground plane" if the roof and/or its structure are conductive (e.g. concrete and iron) then 3m from roof will be ok
