Perhaps goofy antenna idea
Jock Elliott
Re: Perhaps goofy antenna idea
Post by Jock Elliott »
Wow, Andrew, just wow!
Someday, the pie and coffee are definitely on me!
Jock Elliott wrote: Fri Sep 30, 2022 4:21 pm Wow, Andrew, just wow!
nothing special, Jock, just some hopefully useful ideas, check if one of them may be applied in practice
As for the LoG (Loop on Ground), check these
http://radio-timetraveller.blogspot.com ... noise.html
https://frugalradio.com/my-loop-on-grou ... na-worked/
https://rudys.typepad.com/files/630m-log-notes.pdf
to have an idea of what to expect from such a simple, invisible antenna
Jock Elliott
I will check those out.
Jock Elliott wrote: Sat Oct 01, 2022 12:15 pm I will check those out.
let me know...
as a note, a good combo for your QTH could be a LoG for the lower frequencies (lower SW, MW and below) and a SULA for SW and up to VHF, such a setup would give you an extensive bands coverage with just two antennas :) !
Also, your preamp/preselector may work pretty well with a LoG, so it could be an additional interesting test, just... use plastic or wood stakes to keep the LoG wire down on ground, don't believe those who suggest to raise it or use metal stakes, those just didn't understand the LoG, mind me
Jock, any update regarding outdoor antennas ?
N3BE
Post by N3BE »
Maybe not so goofy,
For decades as a renter and home owner, in every room I have used for radio receiving, I put up an 'alarm foil loop' around the perimeter of the room at the top of the walls bringing the foil down to the termination blocks near the listening position. Painting over the foil has no impact on performance. I currently use this method out in my wife's gardening shed for listening away from the powered house on portables.
73 and best DX to all, N3BE
listening since '62.
Jock Elliott
Andrew,
No progress. Been busy. More soon.
